Tranki Wako no pasa na
Yo me muero por poner que los espejos se plieguen con el mando al cerrar las puertas
Uffff, a mi tambien me gustaria poner eso pero yo desde luego sin los asientos electricos va a ser imposible.
Venga, aquí tenéis la explicación directamente extraida de Ross-Tech del funcionamiento:
Central Convenience Controller Coding:
State Bit Dec. Function
OFF 0 1 Great Britain- alarm system (only with bit 4)
OFF 1 2 flash on when arming/unarming alarm system
ON 2 4 selective locking 1 door/all doors
ON 3 8 activate alarm system
OFF 4 16 rear unlocking block via speed
OFF 5 32 locking via speed
OFF 6 64 comfort functions with remote (adapt in ch 62!!)
OFF 7 128 right side steering
OFF 8 256 avant (glass break sensors in rear side-and rear
windows (if error: safe-LED constantly lit ))
ON 9 512 1x flash when lock with remote
ON 10 1024 horn sounds when lock with remote
ON 11 2048 door/window-logic ( ignition off: No open door
el. windows works 10 min )
OFF 12 4096 normal/?
-alarm system
ON 13 8192 No SAFE-function USA only
OFF 14 16384 insulate-glass PR-nr 4KR/4KV
Again, we can verify that we did this correctly by adding up all the decimal values for the bits that are ON:
4 + 8 + 512 + 1024 + 2048 + 8192 = 11788.
Now notice that bit 6 with a value of 64 and function "comfort functions with remote (adapt in ch 62!!)" is OFF !!! So in order to turn this ON, we need to add 64 to the original coding. 11788 + 64 = 11852. Recode the module with that number. Once you do that, the options in Adaptation Channel 62 should take effect, and you can change the value there to "fine tune" the features..
If you wanted to add "locking via speed" (where the car locks itself as soon as you reach some low speed), you would add 32.
If you wanted to turn Selective Locking OFF, (so the entire car unlocks with one press of the unlock button on the remote) you would subtract 4.
joder Rafiki como dominas!!!!!!! yo ni en lo mas basico lo entiendo, por ejemplo: BIt Dec OFF 0 1 Great Britain- alarm system (only with bit 4) me puedes explicar como se conecta esto, bit? dec? por cierto me he intentado meter en elenlace que dejaste de la pag. 7 y me ha sido imposible se queda pensando y no abre la pagina. Del ESP habla algo? Gracias, saludos
Esto es todo lo que se puede activar/desactivar: https://wiki.ross-tech.com/wiki/index.php/Audi_A4/S4/RS4/Cabriolet_%288E/8H%29 Ahí viene detalle por detalle y página por página todo el software del VCDS, como dije en la página 7, para el Exeo aún no esta publicado el manual, este es del A4 B7 pero por lo que he visto es prácticamente idéntico. En el ejemplo anterior, lo único que nos interesa es el campo decimal, el bit es la posición pero eso no se puede cambiar, por ejemplo, en ese ejemplo no esta activado la alarma de gran bretaña porque no ha sumado ese número al resultado que ha puesto en el campo de SOFT CODING, para activarlo como bien indica, tendría que sumar 1 al resultado final, es decir: 4 + 8 + 512 + 1024 + 2048 + 8192 = 11788 11788 + 1 = 11789 De este modo estaría activado todo lo que hemos sumado, esto en el VCDS viene explicado mas o menos, ya que siempre aparece la ventana emergente diciendote lo que tienes que sumar (+1024) con la función resultante de esa suma. Bueno, parezco un matematico jajajaja, esto parece complicado pero cuando tengais el cable en la mano lo vereis mas facilmente, en el fondo es una tonteria.
no, no, esta muy bien la explicacion. si no he entendido mal es sumarle al total, el valor que marque el campo que te interese, no parece tan dificil, probaremos cunado llegue el cable
Seat Exeo | 150
ya tengo mi cable!!! esta tarde a trastear un poco [El archivo ha sido eliminado]
rafiki, has visto por algun lado desactivar el aviso de cinturon?
un abrazo!!
un abrazo!!
Si, en el módulo 17 de instrumentos:
00xxx?x: Seatbelt Warning
* 0 = No Seatbelt Warning
En este modulo mismo, si no he leido mal, si activas lo de Canada automáticamente aparece el mensaje del embrague en el FIS y suenan las puertas al abrirse:
00xx?xx: Country
* 3 = Canada (CAN)
Seat Exeo | 95
-RAFIKI donde dices que explicas lo de los pitidos? en la pag7? el enlace de vagclub que pusistes en la pag7 es de un Octavia y el Octavia lleva unidad de 19bytes por lo que todo lo que explica no vale, y el enlace que pusiste de la WIKI Rosstech ya hace dias que estaba puesto, explicaras donde esta lo de los pitidos o lo volveras a poner??
Seat Exeo | 95
-Alguien a probado lo del cierre automatico de ventanas cuando llueve?? ami no me va, de momento de todo lo que e puesto lo que no va es lo del pitido de puerta abierta y lo del cierre de ventanas al llover, alguien a visto algo mas ![]()
Pues tan facil como sumar a mi no me va,ya qye solo me funciona el cierre selectivo de puertas y un pitido cuando cierras el coche,pero si me va el pitido no me parpadean los intermitentes. Alarma GB (no Americano) Confirmacion del sistema antirobo(un destello) Cierre centralizado selectivo Sistema de aviso antirobo Cierre de la tapa del deposito a 5 km/h Cierre centralizado a 15 km/h Funcion confort via mando volante a la derecha avant confirmacion de cierre por mando (un destello) Confirmacion de activacion de sistema de alarma antirrobo regulador logico de puerta/ventana aviso tatchan de sistema antirobo ninguna funcion de seguridad ventanas laterales con cristal aislante. Luego hay que saber que hace cada cosa,por ejemplo que es eso de alarma GB? sistema de aviso antirobo? funcion confort via mando? regulador logico de puerta ventana? Si activas el sistema canada,sale lo del pisar el embrague,el pitido de puertas....que a mi no me va,pero al poner canada activas algo mas?es que hay que saber si compensa o no activar ciertas cosas.
Seat Exeo | 95
-GSRO en el coding del module 46 pon 7806 que es con todo activado: alarma, pito al cerrar, intermitentes al abrir y cerrar, alarma thatcham, cierre selectivo etc etc, la alarma GB es alarma modo britanico, pero no cambia nada, sistema confort es ke manteniendo el boton del mando pulsao se cierran o abren las ventanas.
jlu1.8t para que pite al abrir las puertas con el motor en marcha y a partir de 15 Km/h es eligiendo Canada en el modulo 17, yo no lo he probado pero así lo he leído en Audi, no obstante a mi no me hace demasiado gracia cambiar a Canada porque no se que mas cambiara y eso me da algo de miedo.
Del modulo 46 traducido del todo es esto:
+ 1 Alarma "estilo Gran Bretaña". (No disponible para vehículos de Estados Unidos). Personalmente no he notado diferencia en el A4 B6, pero en otros modelos, cambia el sonido de ésta.
+ 2 Confirmación de la activación de la alarma mediante parpadeo de los intermitentes.
+ 4 Cierre Selectivo. Si la función está activada, cambia la forma de abrir las puertas con el mando a distancia. Si pulsamos una vez el mando, se abre sólo la puerta del conductor y la tapa del depósito de combustible. Si pulsamos el mando dos veces seguidas (ojo, las pulsaciones tienen que tener un poco de intervalo, no es como el doble click del ratón de un ordenador) se abrirían todas las puertas y el maletero.
+ 8 Activación de la alarma. No hace falta explicación, ¿no?
+ 16 Cierre del maletero al superar los 5 km/h
+ 32 Cierre de todas las puertas al superar los 15 km/h. Al quitar el contacto y sacar la llave del bombín, automáticamente, se desbloquean todas las puertas. Para desploquearlas manualmente, pulsar el botón que hay en la puerta del conductor o tirar de la manilla de apertura 2 veces. En caso de accidente (con la activación de los airbags) las puertas se liberan automaticamente para facilitar el rescate de los ocupantes.
+ 64 Activación de la función Confort. Esta función permite el cierre o la apertura de las ventanillas manteniendo pulsado el boton de cierre o de apertura del mando a distancia.
+ 128 Es la codificación para los vehículos que llevan el volante en el lado derecho. Lógicamente sólo es válida en Inglaterra, Irlanda, Escocia, India, Australia.......
+ 256 Codifiación para los coches que son Avant
+ 512 Confirmación del cierre del coche mediante parpadeo de los intermitentes
+ 1024 Confirmación de la activación de la alarma mediante pitido correspondiente
Por lo que para que pite, quizás no haya que sumar 1024, si no habrá que sumar 512, no se si me explico, ¿habéis probado sumando 1024 y no funcionar? ahora a ver si esta tarde cuando saque el coche lo pruebo.
Efectivamente, acabo de probarlo en el coche, y sumando 1024 se activa la opcion de que al cerrar pite, el pitido es una mierda pero pita, eso si, al abrir no pita nada.
Aquí están los códigos para cambiar el tema de iluminación, hay que acceder al Adapting para ver los canales del módulo 09.
Coding
* ?xxxx: Chassis
o 0 = Limousine (PR-K8B)
o 1 = Avant (PR-K8D)
o 2 = Cabriolet (PR-K8K)
* x?xxx: Driving Light Switch
o 0 = Rain/Light Sensor (G397) not installed (PR-8K0/8K1/9C6/8K4)
o 1 = Rain/Light Sensor (G397) installed (PR-8K3/8K7/9C7/8K9)
* xx?xx: Trailer Hitch
o 0 = Trailer Hitch not installed (PR-1D0)
o 1 = Trailer Hitch installed (PR-1D2)
* xxx?x: Headlights
o 0 = Halogen Headlights w/o Daytime Running Lights (PR-8Q0/8Q1+8K0/8K7)
o 1 = Halogen Headlights with Daytime Running Lights (PR-8Q0/8Q1+8K1/8K3/9C6/9C7)
o 2 = Bi-Xenon Headlights with Daytime Running Lights (PR-8Q3/8Q5+8K9/8K4)
o 3 = Bi-Xenon Headlights w/o Daytime Running Lights (PR-8Q3/8Q5+8K0/8K7)
o 4 = Bi-Xenon Headlights with Daytime Running/Tail/License Plate Lights (PR-8Q3/8Q5+8K1/8K3)
* xxxx?: Country
o 1 = Rest of World/Nordic Countries/Denmark/Croatia/Baltic Countries with Bi-Xenon
o 2 = Nordic Countries/Denmark/Croatia/Baltic Countries without Bi-Xenon
o 3 = USA/Canada with Bi-Xenon
o 4 = Canada without Bi-Xenon
o 5 = Special Vehicles
Adaptation
Channel 001: Coming Home Time
Activation Time of the Coming Home Lighting.
* Standard: 30 Seconds
* Range: 0...60
* Increments: 1 Second
Channel 002: Brake Light Dimming
* Standard: 30 %
* Range: 13...40 %
Channel 003: Tail Light Dimming
* Standard: 32 %
* Range: 13...40 %
Channel 004: Rear Fog Light Dimming
* Standard: 28 %
* Range: 13...40 %
Channel 005: Daytime Running Lights Dimming (Low Beam)
Affective with Halogen only.
* Standard: 92 %
* Range: 51...100 %
Channel 006: Daytime Running Lights Dimming (High Beam)
Affective with Bi-Xenon only.
* Standard: 70 %
* Range: 51...100 %
Channel 007: Daytime Running Lights Dimming (Fog Lights)
Affective for Canada only.
* Standard: 92 %
* Range: 51...100 %
Channel 008: Daytime Running Lights
* Standard: 1 (ON)
* 0 = Daytime Running Lights OFF
* 1 = Daytime Running Lights ON
Channel 009: Switch-Off Delay (Low Beam)
Low Beam Switch-Off Delay with Light Switch in AUTO Position.
* Standard: 51
* Range: 0...64
Channel 010: Low Beam Response
* 0 = Parking Lights OFF after Terminal S OFF
* 1 = Parking Lights Remain ON after Terminal 15 OFF
Channel 011: Low Beam Response (Terminal 15)
* 0 = No Parking Lights
* 1 = Alarm at Door Open
* 2 = Parking Lights OFF at Door Open
Channel 012: Highway/Comfort Blinking
* 0 = Highway/Comfort Blinking OFF
* 1 = Highway/Comfort Blinking ON
Channel 013: Wiper Setup
* Standard: 115
* +001 = Speed Reset
* +002 = Short to Plus Monitoring
* +004 = Rain Sensor active
* +008 = Long Post Wiping after Washing (Drop/Tear Wiping)
* +016 = Speed dependent Wiper interval active
* +032 = Headlight Washer System active
* +064 = Reverse Gear Wiping active
Channel 014: NAR Parking Light Deactivation
* 0 = Parking Lights inactive
* 1 = Parking Lights active
Channel 016: Fog Light Cold Diagnosis
* 0 = Fog Light Cold Lamp Diagnosis active
* 1 = Fog Light Cold Lamp Diagnosis inactive (i.e. for DTM Edition)
Channel 020: Rain-/Light Sensor Setup
* Standard: 2
* +01 = Highway Light
* +02 = Rain Light
* +04 = Rain Closing (Sunroof & Windows)
Channel 021: Assistance Light Sensor Correction
* Standard: 59 %
Channel 022: Transmission Grade (Front Window)
Rain Sensor Transmission Grade at 880 nm.
* Standard: 45 %
Channel 081: Component Protection
To start the process of Vehicle Identification Number (VIN) learning, enter/save 46992 as new value.
bueno pues e estado urgando un poco, y ya tengo kitado el aviso del cinturon de seguridad y ke pite cuando cierro el coche. si luego tengo un rato pongo capturas ke e echo de los modulos segun modificaba. lo ke no e conseguido es lo del cierre automatico de ventanas y techo cuando llueve, al compi le pasa lo mismo, asike imagino ke algo ai ai ke nos esta jodiendo la pava, ademas si os fijais es el unico canal en el ke pone +01 +02 +04, en todos los demas es solamente poner el valor 0 1 o 2 o el valor del porcentaje. un abrazo y gracias por toda la info y ayuda ke nos estas pasando rafiki.
como soy un zoquete en estas lides y me da pánico tocar el VAG-COM, quien se ofrece en Madrid a modificarme todas estas cosillas? A cambio ofrezco unas cervecillas, jeje
Seat Exeo | 95
-RAFIKI lo del pitido al cerrar ya lo teniamos, para estas unidades hay bien poco o abra que modificar una serie de cosas para que funcione algunas opciones, lo del cierre de ventanas y techo pone +1 +2 +4 porque se le puede activar hasta tres funciones, si quieres las tres habra que poner un 7 [09] - Central Electronics Canal 020: Sensor de lluvia instalación Estándar: 2 +01 = Luz a la autopista +02 = Lluvia +04 = Cerrando Lluvia (techo y ventanas) *quizas no funcione sino se tiene techo electrico, quien tenga techo electrico y senson de lluvia que lo pruebe
Seat Exeo | 95
Toma rafiki todo lo del modulo 9 CENTRAL ELECTRONICS traducido Adaptación Canal 001: Coming Home Time De activación de la iluminación Coming Home. Estándar: 30 segundos Rango: 0 ... 60 Incrementos: 1 segundo Canal 002: tenue luz de freno Estándar: 30% Rango: 13 ... 40% Canal 003: Luz trasera de atenuación Estándar: 32% Rango: 13 ... 40% Canal 004: La luz antiniebla trasera Enfriamiento Estándar: 28% Rango: 13 ... 40% Canal 005: Faros diurnos de atenuación (Low Beam) Afectiva con halogenados. Estándar: 92% Rango: 51 ... 100% Canal 006: Faros diurnos de atenuación (High Beam) Afectiva con Bi-Xenon solamente. Estándar: 70% Rango: 51 ... 100% Canal 007: Faros diurnos de atenuación (Fog Lights) Afectivo para Canadá solamente. Estándar: 92% Rango: 51 ... 100% Canal 008: Luces de circulación diurna Estándar: 1 (ON) 0 = Daytime Running Lights Off 1 = Daytime Running Lights On Canal 009: desconexión de retardo (Low Beam) Bajo Manga desconexión de retardo con Interruptor de luz en posición AUTO. Estándar: 51 Rango: 0 ... 64 Canal 010: Bajo Manga Respuesta 0 = OFF después de Luces de Estacionamiento de Terminal S OFF 1 = Las Luces de Estacionamiento quedan encendidos después de la Terminal 15 OFF Canal 011: Bajo Manga respuesta (Terminal 15) 0 = No Luces de Estacionamiento 1 = Alarma en Open Door 2 = Las Luces de Estacionamiento OFF en Open Door Canal 012: Highway / Confort Intermitente 0 = Autopista / Confort Parpadeo OFF 1 = autopista / Confort a parpadear en Canal 013: Wiper el programa de instalación Estándar: 115 001 = Reset de velocidad 002 = Short así como un seguimiento a 004 = sensor de lluvia activa de 008 = Long Post Limpieza después de lavar (Drop / Tear Limpieza) 016 = Velocidad dependientes Wiper intervalo de activos 032 = Headlight Lavadora sistema activo 064 = Engranaje para Limpieza de activos Canal 014: NAR Parking Light Desactivación 0 = Las Luces de Estacionamiento inactivos 1 = Las Luces de Estacionamiento activos Canal 016: Niebla Cold Light Diagnóstico 0 = Niebla Cold Light Lámpara Diagnóstico activos 1 = Niebla Cold Light Lámpara Diagnóstico activa (es decir, para DTM Edition) Canal 020: Rain-/Light Sensor de instalación Estándar: 2 01 = Luz a la autopista 02 = Lluvia 04 = Cerrando Lluvia (Sunroof y Windows) Canal 021: Asistencia sensor de luz de corrección Estándar: 59% Canal 022: Transmisión de Grado (Frente Ventana) Sensor de lluvia Transmisión de grado a 880 nm. Estándar: 45% Canal 081: Componente de Protección de Para iniciar el proceso de Número de Identificación del Vehículo (VIN) de aprendizaje, introduzca / Guardar 46992 como nuevo valor.
Seat Exeo | 176
Yo he estado tocando poquito esta tarde y lo del cierre de ventanas y techo que viene en 02 le puesto 06 y echando agua con una botella encima del sensor de lluvia no a hecho nada el coche, y las otras dos cosas de autopista y lluvia no entiendo para que sirve.. me lo podeis explicar??? gracias y un saludo
