Change axle shafts, steering bar and ball joint, stabilizer silentblocks and bearings
Iniciado por ryleybob, hace 4 horas
bmw | Bolivia | 1
Publicado hace 4 horas
Well, I got into trouble with the famous steering clunk, and the driveshafts that had play and were starting to leak grease.
But when I got down to it, I discovered that the bearings had some play and weren't making any noise...
I don't see the need for a DIY since everything is well explained in Elsa.
I'm waiting for the bearings to start riding.
Let's see if I can stop the fucking vibrations once and for all...
Brake discs to be machined, then tires changed and align. I only found a Meyle hub + bearing kit. Steering rod and ball joint kit €70. Febi 160 driveshafts. 160 bearings. Silentblocks. 14. Wheels + aligner €250. A drama. Makes screws that are single use. And a pair of special wrenches €30. Then a lot of patience.
