McDonald presents his Exeo 1.8T Style from The Netherlands
Iniciado por McDonald, 14 July 2011 a las 22:26
38 post en este tema
  • Seat exeo 3r | León | 6.006
    Publicado 06 September 2013 a las 23:17
    We're leaving very nice. That discharge valve doing?
    Seat Exeo | 26
    Publicado 17 September 2013 a las 20:23
    Another question.
    Have any improvement on the performance? or only changes it for safety?
    Thanks in advance.
    The performance is that the turbo maintains the pressure much better when changing gear.
    Hope to have a Milltek exhaust by the end of September.  porfa
    Publicado 18 September 2013 a las 0:41
    Good changes and very well elegant
    Seat exeo | Sevilla | 2.753
    Publicado 18 September 2013 a las 8:42
    I like you exeo Mc Donald,When you want change you exeo for my exeo.ok jajajaja.
    Seat exeo | Jaén | 1.455
    Publicado 21 September 2013 a las 18:00
    you have nice car very elegant, enjoy it friend ok
    Publicado 22 September 2013 a las 21:32
    welkom bij de club maatje. Ik hoop dat je een goede tijd hier hebben. erg mooie auto. Flipasteis eh?  mafia
  • Seat exeo | Madrid | 1.362
    Publicado 24 September 2013 a las 12:54
    que bien usas el traductor de google jodio!!
    Seat Exeo | 26
    Publicado 18 October 2013 a las 22:19
    Some good and bad news.
    First the good news.
    Finally I have the Milltek sport exhaust system installed. It sounds good, but not too loud.
    The bad news... earlier I mentioned that I would have a look into upgrading the window switches, see this topic: https://mofler.com/foro/index.php/topic,18207.msg293928.html#msg293928
    I have the switches in the passengers doors installed.
    The problem is that the switch does not return to its neutral position when operating the switch. It looks like the cap is touching the armrest when operating the switch and get stucked.
    So I will remove these switches and install the original switches again.
    Only the switch for adjusting the mirrors will stay (4F0 959 565 A 5PR).
    Este mensaje incluye imágenes subidas por McDonald a webs de terceros (imageshack, megaupload, tinypic etc) hace más de 11 años.
    El Club Seat Exeo no se hace responsable si estos servicios eliminan las imágenes de sus servidores.
    Seat Exeo | 26
    Publicado 30 November 2014 a las 23:40
    A few updates from this year.
    Installed a Hama USB charger:
    New CREE Leds (800 lm) for the DRLs:
    New coil packs. These are better, see here for info: https://www.golfmk6.com/forums/showthread.php?t=45050
    Replaced original intake hose by silicone hose from Forge. Also the hoses from the turbo to the throttle body have been replaced.
    Replaced snub mount. Left is the original and the black one on the right is the new poly-urethane snub mount.
    Replaced the plastic injector cups with aluminium ones (left):
    Audi mud flaps and 10mm spacers:
    New LED side markers, very bright:
    New Goodridge brake hoses:
    Had the car remapped again. First I had the first remap (red) removed, didn't like it.
    Went to another company for a new remap and the car was doing 229 hp / 334 Nm (blue) on the dyno! alegria
    The fuel I was using was RON98 (Shell) and added 10% bio-ethanol for increasing the octane level of the fuel.
    My Exeo is at appr. 2:10 minutes:
    Replaced LEDs footrest and doors with brighter ones:
    Further:
    - Debadged the rear
    - New clutch (Sachs)
    - New timing belt
    Este mensaje incluye imágenes subidas por McDonald a webs de terceros (imageshack, megaupload, tinypic etc) hace más de 10 años.
    Seat Exeo | Málaga | 3.529
    Publicado 01 December 2014 a las 1:24
    Donde se puede comprar los casquillos esos de aluminio donde entran los inyectores. ..??
    Seat Exeo | 26
    Publicado 01 December 2014 a las 13:04
    The injector cups were ordered here: https://www.verdictmotorsports.com/Volkswagen_VW_Audi_Injector_Cup_Billet_1_8T_20v_p/vms107.htm
    Select engine code: AMB.
    Best is to order the complete kit (hex, brush, loctite) and new o-rings for the injectors.
    You might also want to replace the gasket between engine & intake manifold, and the gasket between throttle body & the intake manifold.
    Removing the intake manifold is quit a big job, because you'll also have to drain some coolant.
    Disconnecting the hose from the pipe through the manifold to thermostat was the hardest job:
    My car had the wrong plastic cups installed, revision E (grey) instead of H (white):
    The plastic cups can crack: https://www.audizine.com/forum/showthread.php/543201-What-went-wrong-with-your-B6-today?p=10258271&viewfull=1#post10258271
    It's also good practice to clean and recalibrate (VCDS) the throttle body: https://hubpages.com/hub/How-To-clean-your-Throttle-Body-VWAudi-DIY#
  • Seat exeo st | Madrid | 3.608
    Publicado 02 December 2014 a las 5:22
    Los leds de las DRL no das fallo?
    Donde se pueden conseguir esas bombillas?
    Gracias!
    Publicado 11 December 2014 a las 22:58
    Mc donald good machine. you say that ethanol was added without it, how much power surrendered bank? yours was generous car home, mine, because of the delay in ignition before rescheduling, did not render the original 150hp ... why change coils too.
    A greeting!
    Seat Exeo | 26
    Publicado 12 December 2014 a las 16:16
    A greeting!
    The first time the car was chipped it was doing 184hp with normal petrol (RON95). The second time with new chip it was doing 229hp. This time RON98 petrol was used with adding extra ethanol. I add 1 liter ethanol for every 10 liters of petrol, so it's 7 liters for a full tank.
    Bio-ethanol has an octane value of 109, so adding the ethanol will increase the octane level of the petrol to approximately 100. This will add 10-15hp extra and makes the engine run smoother and better. The higher the octane level of the petrol the better it is for the engine. Some people say the exhaust gases are cooler too.
    With an higher octane value the fuel consumption is a little less too. I used for a short period expensive RON102 petrol and the fuel efficiency dropped from 8.3 to 7.6 liters for each 100 km. You can see my fuel efficiency here: https://www.spritmonitor.de/en/detail/428234.html
    The new coils are more reliable than the original ones used for the 1.8T engine and work better with lower rpm's. These coils can also give more energy (higher voltage) to the spark plugs which makes it possible to increase the gap of the spark plugs. The gap is normally 0.7mm and I increased it to 0.8mm. Some people in the USA with Audi A4 B6 use gaps up to 1.0mm. The bigger the gap the hotter the spark which results in a more efficient burning.
    More technical information about these coils can be found here: https://www.golfmk6.com/forums/showthread.php?t=45050
    I use the NGK BKR7EIX Iridium spark plugs now.
    Publicado 12 December 2014 a las 18:48
    With fuel prices here in Spain ...
    I also took 98 deal specifically map, with option, of course, to use 95.
    The clutch will not slip? Or have you left very smooth torque curve, since I do get to do that effect the second time you retouch reprogramming (not now).
