Club Infiniti Q50/QX50
Climatizador echaba aire caliente y frío
Iniciado por Santi9dea8, 07 December 2022 a las 13:27
Infiniti Q50/QX50 | Salamanca | 3
Publicado 07 December 2022 a las 13:27
Hola. Mi Infiniti Q50 de 2016, 2.2d dio fallos en el climatizador. Le cambiaron una pieza en garantía, costaba 180€ mano de obra incluida, por lo que me dijeron en el taller.
    Infiniti Q50/QX50 | United Kingdom | 9
    Publicado 10 December 2022 a las 14:30
    You probably have a split system air conditioning unit in your home or office and are no doubt familiar with the symptoms of the unit not cooling its room adequately. I prefer to check this briansclub and get more new things for trading. The air conditioner cycles on and off, keeping the temperature inside the house lower than it should be. Sometimes, this is due to high humidity or blocked return vents; other times, it's just a problem with the equipment itself.
