McDonald presents his Exeo 1.8T Style from The Netherlands
Iniciado por McDonald, 14 July 2011 a las 22:26
38 post en este tema
Seat Exeo | 26
Publicado 14 July 2011 a las 22:26
Aloha,
First my excuses for not writing this in Spanish. My (nick)name is McDonald and I am from Rotterdam in the Netherlands.
The car I own is an Exeo 1.8T Style in Magic Black with some extras. I have the Exeo since June 2009.
The following modifications have been added to the Exeo:
- 17 inch Dezent V Dark rims with summer tires
- lowered 30-35mm with Eibach springs
- chiptuned to 195hp
- LED lights interior
- ambient light front
- new light in rear with ambient LEDs
- DRL with LEDs
- LED sidelights
- replaced front blinkers with Philips Silver Vision bulbs
- replaced front fog lights with GP Thunder 7500K Xenon look bulbs
- automatic opening of boot
- hooks in boot (2x)
- RS4 pedals incl. footrest
- RS8 oil cap
- painted brake claws silver-grey
- replaced 12V cap
- chrome exhaust tips
- plastic rain covers in engine bay
- rubber gasket around engine bay
- LEDs in small storage compartment in dashboard
Here are some pictures:
In original state
Now
Painted brake claws
Ambient LEDs in the front
Ambient LEDs in the rear with new reading light
DRL LED
New fog ligths
Engine bay with plastic covers and rubber gasket
12V cap (part no.: 4L0 919 311)
2x LEDs in small storage compartment in dashboard
Este mensaje incluye imágenes subidas por McDonald a webs de terceros (imageshack, megaupload, tinypic etc) hace más de 12 años.
El Club Seat Exeo no se hace responsable si estos servicios eliminan las imágenes de sus servidores.
  • Seat exeo | Valencia | 6.442
    Publicado 14 July 2011 a las 22:34
    welcome to the club.
    Seat Exeo | 859
    Publicado 14 July 2011 a las 22:38
    Hi, Welcome to the Foro Club Seat Exeo in Spain. I like your car and the pictures are very nice. What kind of DLR do you have? Do they give the problem of molten light? Congratulations! 😉
    Seat Exeo | 26
    Publicado 14 July 2011 a las 22:45
    The DRL Leds are from Benzinfabrik in Germany: https://www.benzinfabrik.de/de/led-tagfahrlicht/tfl-audi/smd_led_tagfahrlicht_fuer_audi_a3_a4_a6_tt_q7_tfl_set/
    I only used the LEDs. Replaced the resistors with ones with cooling body.
    Drilled holes in the socket for the wires.
    Resistors are getting appr. 40 degree Celsius. I haven't notice anything melting.
    I made a description with pictures in Dutch (you can use Google to translate): https://www.seat-online.nl/showthread.php?3882-SEAT-Exeo-3R-DRLs-met-LEDs-uitgevoerd
    Seat exeo tdi | Álava | 11.766
    Publicado 14 July 2011 a las 22:53
    Welcome
    Seat Exeo | Madrid | 16.785
    Publicado 14 July 2011 a las 23:43
    Welcome majete!
  • Seat Exeo | Madrid | 16.785
    Publicado 21 July 2011 a las 10:19
    It is our best car in Spain, enjoy healthy.
    Hombre, el best, el best... Está muy bien, pero tanto como el best con las marcas que hay por aquí, resulta un tanto pretencioso creo yo.
    Un saludo!
    Seat Exeo | 316
    Publicado 21 July 2011 a las 12:38
    muy bonito me gustaria saber el modelo de la salida de escape saludos
    Seat exeo 3r | León | 6.009
    Publicado 21 July 2011 a las 14:34
    Welcome ! you have docks sport ? greetings !
    Seat Exeo | 859
    Publicado 21 July 2011 a las 21:50
    Hi Mcdonald!! Congratulations to the " Brico " but I belived that you had the solution without the resistors!! ;D
    I have Make more or less the same system that you and this is my description:
    BRICO MONTAJE LEDS DLR
    Thanks and congratulations for your car. 😉
  • Seat Exeo | 26
    Publicado 22 July 2011 a las 0:02
    I use for each DRL LED bulb 2 resistors of 39 Ohm / 50W (parallel = ~20 Ohm). The resistors are mounted on an alumnium angle bar. The temperature of the resistors is approximately 40 degrees Celsius. No ventilator needed!
    Wires are going through the original socket and are soldered to the contacts.
    Contents of the original package from Benzinfabrik:
    Hope to install clear side blinkers this weekend.  😉
    Publicado 27 July 2011 a las 21:55
    Wellcome and good luck
    Seat Exeo | 26
    Publicado 13 August 2013 a las 0:36
    Haven't been active on the forum for a while so I will give you a small update.
    Replaced the blinkers for clear ones:
    Replaced rear lights and license plate lights for LED units:
    Replaced original DV for a Forge 008:
    Have the footrest and puddle lights in the doors installed (all LED):
    Replaced front and rear brakes and pads for EBC Ultimax discs and Redstuff pads:
    Tip: If you ever want to replace the rear discs you need the following 8mm hex key from Laser Tools (part no. 5584) for removing the callipers: https://www.lasertools.co.uk/item.aspx?item=10964
    Este mensaje incluye imágenes subidas por McDonald a webs de terceros (imageshack, megaupload, tinypic etc) hace más de 10 años.
    Seat exeo st | Toledo | 524
    Publicado 13 August 2013 a las 1:02
    congratulacions you have a nice car
    Publicado 13 August 2013 a las 11:20
    good modifications! what is the forge? what is the use? Sent from my iPhone using Tapatalk
    Publicado 20 August 2013 a las 17:58
    It's a diverter valve also called a turbo circulation valve or blowoff valve (https://en.wikipedia.org/wiki/Blowoff_valve)
    The original valve is completely made from plastic and can malfunction when turbo pressure is increased especially on a chipped (tuned) car.
    The Forge valve I have is the FMDV008: https://www.forgemotorsport.com/content.asp?inc=product&cat=&product=FMDV008
    Thank you so much for the explanation.
    Another question.
    Have any improvement on the performance? or only changes it for safety?
    Thanks in advance.
    Seat exeo | Castellón | 295
    Publicado 06 September 2013 a las 22:37
    Congratulations, great to have another DIY guy here. Just a question, didn't you replace calipers and lines in the brakes mod you've done? I'm asking because I suppose temperature can reach higher with no fadding now. Take care pal.
